Starter/Flexplate Problem
Old Dec 19, 2002 | 11:59 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have a mini starter that suppose to work on 153 and 168 tooth flexplate. However when I install the starter it' about a 1/4in. into the inside of the flexplate, which is preventing the starter from engaging into the flexplate. Has anyone run into this problem before. The engine is a SBC 283 with a 153 tooth SBC 305 flexplate AND HAVE A STRAIGHT BOLT PATTERN.
Old Dec 20, 2002 | 05:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That has the other straight bolt pattern...
The pattern you need doesn't exist on blocks before about 78 or 79, so it's fairly certain your 283 doesn't have it. It needs one additional hole drilled & tapped to use that setup.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
