fuel pump rod
Old Jun 9, 2023 | 11:27 AM
baseball699's Avatar
fuel pump rod
What is the correct fuel pump rod when using a billet steel roller cam? Is GM # 3704817 correct? Is there a quality aftermarket rod that is good to use? This GM number crosses to Dorman 03875 and GMB 5008001
Old Jun 9, 2023 | 12:50 PM
skinny z's Avatar
Re: fuel pump rod
Looks like something with a bronze tip is the way to go.
There are roller tips available as well. I've got one it on the shelf that was targeted for my SBC, but I went to an electric pump instead after a pump cam eccentric went flat.
Similarly, a steel cam requires a unique distributor gear as well. Bronze used to be common but a better substitute, according to Mike Jones at Jones Cams, is a mellonized steel gear (not iron).
It would be interesting to know if such a thing exists for the pump pushrod. A quick search didn't reveal anything though.
Old Jun 9, 2023 | 03:34 PM
Re: fuel pump rod
I've used both bronze tipped ones and roller ones.
Comp 4607 & 4609; Moroso 65750; there may well be others. Crower would be a suspect, Jesel, Manley, any of those guys that do hard-core racing stuff. Somebody has a polymer one also; never used one myself; Howards maybe?
JamesC
Dec 18, 2013 03:09 PM
skinny z
Carburetors
Sep 13, 2011 08:32 AM
Clutch793
Carburetors
Nov 9, 2009 06:57 AM
phess11
Carburetors
Nov 14, 2006 10:49 AM
ATXJester
Feb 26, 2002 06:33 AM
