Anyone know the lobe center of the LT4 cam?
Old Jan 21, 2002 | 05:05 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I have the rest of the info like lift and dur@.050 and LSA. But I don't know the lobe center.
Old Jan 21, 2002 | 05:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
111.9 .
Old Jan 22, 2002 | 08:41 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I heard that the lsa was the exact opposite of the one needed for a tpi.
Old Jan 23, 2002 | 03:34 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Yes, that is why everyone installs it 180 degrees out of phase. It works best that way.
Old Jan 23, 2002 | 07:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Anyone know the lobe center of the LT4 cam?
The lobe center is the LSA. L-obe S-eperation A-ngle.
Are you asking about the intake centerline? That's the amount of degrees that the intake lobe centerline is in realation to TDC. It's measured in crankshaft degrees. A cam installed @ 108* intake centerline means that the lifter is at the center of the intake lobe at 108* ATDC on the intake stroke.
If that is what you're trying to find out, then it's a good question. I have never seen the int. cntrline posted on any GM cams, ever. It would help out if we could know that.
AJ
angel2794
Sep 8, 2015 06:22 PM
f-bodyz28
Sep 2, 2015 05:03 PM
masonta
Sep 1, 2015 06:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
