Fuel Pressure Regulator Question
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
I’m running a stealth ram with stock TB (‘87) and Holley fuel rail kit 9900-172. The kit comes with an adjustable fpr. I have the vacuum for it running to the very small port on the bottom of the throttle body. Is this an OK location or should it go directly into the upper plenum?
Transmission: T-5, TH350, T-5
Re: Fuel Pressure Regulator Question
Plenum. The TB is ported vacuum which will have no vacuum signal at idle, therefore full fuel pressure.....at idle when you need the least fuel pressure.
Engine: SBC 350
Thanks. Could this be the cause of a “surging” I’m experiencing?
Engine: SBC 350
Ok, so another dumb question. Should MAP go to ported or plenum?
manifold vacuum not ported
