14102187 heads
Old Jan 21, 2002 | 08:19 PM
AdioSS's Avatar
Car: 96 Impala SS
14102187 heads
A guy on a local board was giving away some center bolt 305 heads, so I took him up on the offer. Here's some info I found about them on the web.
Casting #14102187
Combustion Chamber size CCs 58cc
Intake valve 1.84
Exhaust valve 1.50
Production Years 1987-91
Engine 305
CHEVY 1986-89 305 5.0 3.736 V-8 Flat Tappets, 1 Piece Rear Seal,
I'm gonna try my hand at pocket porting them and put them on my TBI 305cid L03 when I swap a new cam in.
Are these good heads a good starting point?
Cheston
Old Jan 22, 2002 | 08:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably not...
Looks like swirl-port TBI heads to me.
Heads don't care whether the cam is roller or flat tappet, that's a red herring.
Old Jan 22, 2002 | 09:39 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
1986-88 14089119 350 1.94 1.5001 - EFI
1987 14101083 350 1.94 1.5001 - EFI
1987 14101128 350 1.94 1.5001 - EFI
1986-88 14102191 350 1.94 1.5001 - EFI, swirl port
1986-88 14102193 350 1.94 1.5001 - EFI
1986-91 10110810 305 1.84 1.5001 - EFI,swirl port, stat wgn
1986-91 14101081 305 1.84 1.5001 - EFI, std port
1988-93 14102188 350 1.94 1.5001 - EFI, swirl port
1986-91 14102187 305 1.84 1.5001 - EFI, swirl port
I'd start with a set of "081" heads. The castings are fairly clean
and should port up ok for a budget buildup
The "187" heads have a big swirl vane in the intake port,
which may be just the thing for gas mileage, but that vane
will really cut down the airflow and limit the HP.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
