Fuel sending unit
Car: One Chevy built in the 80s
Engine: 5.7 crate
Axle/Gears: Quick performance 9” 3.70
Fuel sending unit
Curious if there is a way to “bench check” a fuel sending unit? Currently I have my tank dropped for refurb and seems like a good time to make sure it works. Not ripping all that stuff back out so is there a way to check it? I’m guessing if I plug it back in and move the float in theory the gas gauge should move? 305 carb engine…for now
Re: Fuel sending unit
Yes of course you can just hook it up to the car and check using the gauge. Works fine. Might have to use a clip lead or some such to ground its flange.
