89 fb 350tpi won’t run without starting fluid
Car will start with starting fluid but will stall as soon as it drys out.
it sat for about 10 years before I bought it which I have replaced fuel pump and have verified I’m receiving 60-80lb at fuel rail.
injectors are all pulsing and have cleaned few of the plug(changing them with new soon)
anything else I should pay attention to before I pull fuel rain and buy a rebuild kit ?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 fb 350tpi won’t run without starting fluid
I’m surprised you have such high fuel pressure.
replace the regulator and injectors and report back.
if you have a noid pulse there varnished shut. Sk24 standard motors rail o-rings or source everything but the pump at southbay fuel injectors.
and gas was all varnished car did run when parked .
did replace fuel filter as well anything else to check before pulling plenum for rails
Engine: Lb9
Transmission: M20
If there a grey body multec injector it’s a wasted effort to keep them alive . The regulator has to be sticking shut to get 80psi at the rails or there an obstruction in the return line .
would clog in regulator/return line cause an issue with starting since regulator is on return line?
Engine: Lb9
Transmission: M20
The increased fuel pressure would cause higher fuel flow.
I used a test light to verify all injectors was firings via electrical of wire so thinking it’s the injector gummed up
will starts after sitting but instant stall and back to needing starting fluid
had small life issue so didn’t get a chance to work on it more hopefully have her up and running soon
EastonFrench
Apr 17, 2016 05:05 PM
Bullydawg
May 17, 2008 01:48 AM
