Engine Randomly Dies...Starts right back up with starting fluid???
Old May 16, 2008 | 12:39 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I might be buying a Camaro Z28 305tpi with a 6 speed swapped in. Well, it will drive great for a few while (5-10 miles), then it will die. Then if you spray it with starting fluid and it starts right back up and runs great for a while again and the process repeats. What could be causing this?
Old May 16, 2008 | 03:07 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Engine Randomly Dies...Starts right back up with starting fluid???
Anyone?
Old May 16, 2008 | 03:32 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Originally Posted by Bullydawg
Anyone?
Fuel pump?
Old May 16, 2008 | 04:16 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
could be a fuel pump or just a dirty fuel filter
Old May 16, 2008 | 05:11 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Fuel Filter is new. I dont see why a fuel pum pwould be spuratic though.
Old May 17, 2008 | 01:30 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
What yr. is the Z? TPI or throttle body? Any codes from the ECM?
Old May 17, 2008 | 01:36 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
TPI has a throttle body. It is TPI as posted above. I am not sure there are any codes. I dont think there are.
Old May 17, 2008 | 01:48 AM
pintaman's Avatar
Car: several camaros (depends on mood)
Engine: small blocks
Transmission: muncie,supert10,350,700r
Axle/Gears: 323,373,456
well...I would try a fuel pump pressure test 1st thing.Its not unusual for one to act that way.Also before she dies does it run rough or just drop off like turnin the key off?
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
killer777
Aug 8, 2015 02:47 PM
