Rough idle out of no where
Old Sep 3, 2023 | 12:29 AM
josh1202's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 liter
Car struggles to start and when it does it idles rough, struggles to stay running and engine shakes. We previously replaced the distributer + cap + rotor + wires + plugs, the ICM, TPS, IAC and Temp sensors. Car was running good in the morning parked it, came back to start it in the afternoon and was like this. The last work I did was simply remove the PCV and opposite side vent tube in exchange for breathers and capped the corresponding inlets on the intake (Made it run even better). Anyone know what the problem could be, tips what to do?
Old Sep 3, 2023 | 05:55 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Rough idle out of no where
Can you get a scan (data log)?
'em TPI systems can be tricky to fix without seeing what the ecm/sensors are doing
$750 L98
Mar 23, 2016 02:57 PM
BlackenedBird
Nov 9, 2011 04:56 PM
Shadygrady
Jun 12, 2008 08:35 PM
91ChevyRS
May 16, 2006 03:14 AM
