Why does my car do this?
Old May 11, 2006 | 05:12 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
So pretty much the problem I am having with this car is an odd one, it doesnt occur every time but it does get annoying when it happens.
On my way home today, I was at a stoplight and something was wrong, I looked at my RPM gauge and found that the idle was sitting at 500.
Some people will say its normal for the car to be that low, but not on mine. The idle usually sits anywhere from 550-650, usually sits at 600.
Basically whenever the idle gets that low the car starts acting terrible, I have to stop very very slowly otherwise if I stop hard or just stop in general, the car will die and it will be a pain in the *** to start it up again.
What it will do during this phase is the idle will lope back and forth, it will sometimes jump just below 500 and then quickly spring back up (this happens when I am braking)
I have done all the service maintenance, plugs, distributor cap, rotor, fuel filter, TPS, O2 sensor...
The only thing I have yet to do is plug wires. I do have a miss in the car..and I know its probably my plug wires because they are in pretty bad shape...
Anyways, is there anything else that might be causing this?
Old May 11, 2006 | 05:46 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Do a search on adjusting the IAC (Idle Air Control) and TPS (Throttle Position Sensor). Come to think of it, there may be a tech article on it. Anyway, that helped smooth out my idle.
*edit*
Here it is:
https://www.thirdgen.org/tpimod2
This is for a TPI car but it's the same idea on a TBI.
Old May 11, 2006 | 06:06 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
iac is stuck or dirty
Old May 11, 2006 | 06:42 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
check the IAC, and get a set of performance wires. Your beat up wires might be arcing and causing you to miss, like you mentioned.
Old May 12, 2006 | 01:01 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
My 91RS purrs at 500rpms after warmed up. Never has stumbled on me yet.
Old May 15, 2006 | 06:42 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
where is the IAC located? Dumb question I am aware...
Spark plug wires shouldnt be a problem to replace, however, can anyone recommend me some good durable ones. I don't care for performance Accel or MSD ignition wires cause I dont have the time nor does my car need such wires...
I was thinking more along the lines of AC Delco...or Duralast....or even Autolite...I don't wanna spend more than 40 dollars on a set
Old May 15, 2006 | 06:48 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
if you get duralast, spring for the lifetime wires. That way, just say the wires are arcing every other oil change and get free ones lol.
Old May 15, 2006 | 08:00 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
The IAC motor is on your tb. It works like a plunger letting in air or shutting it off.
Old May 15, 2006 | 08:02 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
IAC located the same side as the TPS on your TBI. The IAC has 4 wires going into it.
Old May 16, 2006 | 03:14 AM
c-a-m-a-r-o_92's Avatar
Car: 92 25th anniversary camaro
Engine: 305 (HO)
Transmission: 700 r-4
Axle/Gears: 3.43
too much to list
okay firs check and see if your a/c is on when you stop my cars a/c would kick on and off and that always killed my engine but an easier not check your ditributor position / timing and if that doesnt work you could always adjust your throttle linkage to make your car idle higher
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
