Water temp in Engine bay
Old Sep 3, 2023 | 10:23 PM
Clements408's Avatar
Car: Son drives 1989 IROCZ
Engine: 5.7L TPI, AFR 195, L98
Transmission: 6 spd manual
Axle/Gears: Stock
I'm considering adding a liquid filled water temp gauge on the engine plumbed from the hole on top of the water pump that is normally plugged. The 3/8" brass tube rises up ~8" before dead ending on the gauge.
My concern is an air pocket will most like form when the engine is off so will the flow of water flush out the air pocket or will air get stuck up by the gauge resulting in incorrect readings?
I could look for a 3/8" slim design brass air relief valve to resolve but considering this may be going to far so just plug the hole and go without.
Opinions and any real life experience are welcomed
Old Sep 4, 2023 | 03:02 PM
Re: Water temp in Engine bay
How about something more generally useful, like this? https://www.harborfreight.com/121-in...ter-63985.html
Old Sep 7, 2023 | 09:40 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Why tho?? Do you not have a working gauge?? Or just use a temp gun
Old Sep 7, 2023 | 12:16 PM
Axle/Gears: Stock
I have the gauge on the dash. Decided not to install on engine, after thinking about it for a day, agree it's too much.
gta_knight
Aug 16, 2014 09:01 AM
dandsspanel
Feb 28, 2006 01:07 PM
Ryknow86
Aug 17, 2003 03:16 PM
