Engine dies when I put it in gear
Car: 1987 Firebird Formula
Engine: 305 Carbureted
Ok so I have my new engine set up and everything pretty close and I have it to where it will start and idle great but I’m having a few problems. When I try to put it in gear it sputters and dies and I can’t keep it running, and not sure if this is related to it but when I hook up the vacuum advance it revs up to like 2700 rpm and will not ever come back down to idle. Help please because I really have no idea what this could be.
Re: Engine dies when I put it in gear
Vacuum advance? On an '87 Firebird? That sounds like a non-stock arrangement. A lot more information will be necessary to describe the system before meaningful advice can be offered. The stalling on gear engagement is sometimes a lean condition.
not sure exactly what you’re talking about but I’m using the same tach that’s always been there and it always worked fine. Also I can hear it rev way up. Not 100% sure the number is accurate but it seems accurate to me based on what it sounds like
its a new engine and very far from stock lol, I could tell you everything I’ve put on it if that would help. I’ll try messing with the fuel-air ratio on my carb and see if that makes a difference though.
wavy-pointer "sporty" trim package in the dash
They are well and widely known, notorious even, for failing, by reading WWWWWAAAAAAAAAAYYYYYYYY high. I had one in my possession at one time that read 3 times the true engine RPMs. They're never particularly accurate to begin with; the chip's specs is like 5% accuracy or something.
The point in your case being, if you're setting the engine RPMs to, say, 600 on that thing, but the REAL RPMs are, say, 400, then it's no wonder that the engine dies when you put it in gear, and it goes to 300 or whatever.
Another thing to consider is, whatever you have your "timing" set to before you apply the vac adv, and how you set it. Like the factory tach, the "timing" marks are NOTORIOUS for being inaccurate; most especially, when there's a mismatch between timing cover and crank damper (say, stock damper, and aftermarket "krome" timing cover & pointer). They also suffer from the fact that the "mark isn't on the part of the damper that's actually bolted to the crank, but rather, is on the outer inertia ring, which is only loosely associated with the crank by a BLOB OF SPOOOGE. The inertia ring frequently can move around on the damper hub, taking the "mark" with it; making any kind of "number" you pretend to read with a "light", TOTALLY out to lunch.
You might start by advancing the "timing" to the point at which the engine just begins to ping, then backing it off until it stops pinging; and seeing how far that is from wherever you "thought" it should be. That won't necessarily be exactly "right", in fact probably not although it should be somewhat close, but is often a real eye-opener as to how far off the whole "mark" deal is. You may even find that it's retarded SO far now, that it's almost to the point that the engine won't even run if you retard it any further, which would be a clear indication that it's way wrong.
The factory "tach". Or I should say, the factory "tach-shaped object".
everything on this engine is brand new
