SOLVED '89 305 TPI, SES Check engine light on, code scanner's won't communicate.
Old Oct 6, 2023 | 11:23 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
EDIT SOLVED, My MAF was disconnected! That's what happens when one neglects to do a proper "Visible Inspection: before digging in! EDIT
Regarding my 1989 IROC 305TPI LB9/ AT Ca. car...The SES/Check Engine light comes on moments after startup. Disconnecting the battery for 10 minutes did not cause the SES to reset. Engine seems to have an slight ignition misfire. I tried both my known good code scanners, and they would not communicate with the vehicle.
Coincidentally , OR NOT, this problem came up a few weeks after I installed 8 new Standard Motor Products injectors, overhauled the FI Pressure Regulator. Fuel pressure is at 38 PSI with the vacuum line disconnected(as it was before the work),
Rather than spend HOURS running tests, what part might I throw at it, to maybe get a fix? Ignition Control Module (ICM) ?
Thanks.
Old Oct 6, 2023 | 11:32 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: '89 305 TPI, SES Check engine light on, code scanner's won't communicate.
Will it At least blink codes jumping the aldl ?
Old Oct 6, 2023 | 12:11 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I will try, what terminals do I jump? Thank you.
Old Oct 6, 2023 | 12:16 PM
Engine: Lb9
Transmission: M20
A to B key on engine off
Old Oct 6, 2023 | 01:07 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Jumping A & B (top right and the one to it's left) I get code 12, 33, then 12. Somewhat extended cranking required to start. Which I recently Fixed, by installing a new Fuel Pump Relay (the old one tested bad and upon installing the new relay, extended crank was corrected).
Thanks.
Old Oct 6, 2023 | 01:16 PM
Engine: Lb9
Transmission: M20
Might try to diagnose the maf code
Old Oct 6, 2023 | 01:19 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
DUH! The MAF sensor was disconnected! I broke the retainer clip, when I did the Injectors and did not fix it. Time for some Tyraps. I APOLIGIZE for wasting your time! Mike C
Old Oct 6, 2023 | 01:41 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: SOLVED '89 305 TPI, SES Check engine light on, code scanner's won't communicate.
Runs good, SES light operates properly without staying on. Still will not communicate with my Actron scanner.
Time for me to do a Search and not waste anyone's time. Thanks.
Old Oct 6, 2023 | 07:41 PM
Vader's Avatar
Unless the scanner is VERY old and designed for the early GM protocols, it is unlikely to communicate. Most of those types in the generic (Actron) brands were basically glorified code readers only.
Old Oct 6, 2023 | 10:37 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
My Actron is maybe 15 years old and reads and resets codes, reads livestream data. My OTC2000 is 30+ years old. Neither one will communicate w/ my IROC Z.
mxxdude
Feb 7, 2011 07:49 PM
evilemokid94
Nov 7, 2010 05:00 PM
BCdawg57
Feb 16, 2005 02:09 PM
fastmustang65
Apr 20, 2001 09:55 PM
