Camshaft dowel pins. Replacements do exist right?
Old Nov 10, 2023 | 12:19 PM
SilverChicken's Avatar
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
The dowel pin I removed that is too short measures .246” in diameter. When I search for SBC cam dowel pins I only get 5/8” pins in the results for FT cams I assume but nothing for the roller cams. Where the **** can I find one of these? It needs to be extra long and not hardened steel.
Old Nov 10, 2023 | 12:46 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Camshaft dowel pins. Replacements do exist right?
Any cam company can provide you with that...
Old Nov 10, 2023 | 03:52 PM
Engine: 383 SBC
While true I was hoping for a more convenient source since the cam companies don’t readily sell them without a cam in the box with it. You have to go through customer service then hope they will sell you what you need and what I need is pretty specific since this is for a gen2 LT1 and needs to be longer than just any other roller cam.
Old Nov 10, 2023 | 11:05 PM
Vader's Avatar
Anyone selling drill rod should have stock to make them by the dozen. That used to be just about every other street in a town that had any sort of manufacturing going on. Now with the internet selling everything and stocking nothing, you may have to wait a week to get a 12¢ piece of stock.
Incidentally, 0.246" is a "D" drill in case you still have a source that doesn't include "home" in the name or description. The stub end of a "D" drill could be cut off to the length you like.
Old Nov 10, 2023 | 11:17 PM
Vader's Avatar
You could also check out McMaster 3023A285. It's Rc 60 hardness, which is just about right for a camshaft (usually Rc50-58 or so).
Old Nov 11, 2023 | 04:14 PM
Engine: 383 SBC
perfect solution! I think the HRC of the dowel is a 58 so you’re right about that. But yesterday, after what felt like an eternity on hold, I got through to Comp, and even though it isn’t their cam, they’re sending me a variety pack of cam dowels. But if that solution doesn’t work I will most definitely go that route. I was even looking into pin gauges as a solution but most of those are hardened and that’s not something you want as a cam dowel even though you should never break one.
Old Nov 12, 2023 | 11:07 AM
skinny z's Avatar
Originally Posted by SilverChicken
... I got through to Comp, and even though it isn’t their cam, they’re sending me a variety pack of cam dowels. .
Props to Comp for that one.
Good luck and I hope you get what your looking for.
Johnny Gun
Jun 23, 2021 12:45 PM
Hotrodder
Feb 4, 2018 08:26 PM
sogabe
Apr 24, 2007 11:17 PM
z28crazy
Feb 13, 2003 07:39 PM
3gc
May 28, 2002 10:13 PM
