Need some help identifying part?
Old Dec 17, 2023 | 09:17 AM
Kk8784's Avatar
Hey y’all! I’m relatively new to all this and I’m still learning so don’t judge to hard, I can’t for the life of me identify this part and the hoses that run to it broke. If y’all could help me out that would be wonderful
Old Dec 17, 2023 | 01:26 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Need some help identifying part?
Part of emissions system
Old Dec 17, 2023 | 05:22 PM
erik69&85's Avatar
A.I.R. injection tubes and check valve... Injects air into the exhaust header for emissions control.
Getting the rusted part out of the check valve will not be easy... Might need to find both.
Old Dec 17, 2023 | 09:21 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
The part on the passenger side that has the tubes running out of it as Erik said, is part of the A.I.R. injections system (e.g. part of the smog stuff). It is missing a small cover that hides the plugs. The missing part is purely cosmetic.
As for the part on the driver side, it is also part of the A.I.R. system. Your tube is broken. You will need to replace the check valve (the black piece), as well as the stainless tubes because it is broken. There are no threads to install a replacement valve. Fortunately for you, that is is the driver side that is broken and not the passenger side. You can replace those tubes on the car fairly easily. You'll want to use a 9/16 flare nut wrench and/or flare nut crow foot to get the tubes off without messing things up.
Old Dec 18, 2023 | 10:47 AM
Kk8784's Avatar
Tyy!!
Old Dec 18, 2023 | 11:06 AM
Kk8784's Avatar
Ty sm!! Appreciate the help
Maninblack002
Sep 15, 2021 06:14 PM
BORLAZ06
May 29, 2003 12:54 AM
Dante93GTZ
Jun 2, 2002 08:40 PM
SSC
Northern Great Plains and Rocky Mountain
Jul 24, 2001 01:04 AM
