91 z28 tpi starts and dies quickly
Old Jan 3, 2024 | 07:22 PM
tuned out's Avatar
I replaced, pump, sending unit and filter. Car starts but won’t stay running. I turn key and security light turns off so I don’t think it’s vats. Any ideas?
Old Jan 3, 2024 | 07:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 z28 tpi starts and dies quickly
Fuel pressure tested ? Original multec injectors ?
does it continue to run off starting fluid ?
injector pulse tested with a noid light ?
hot spark ? Has the car sat for along time?
Old Jan 3, 2024 | 08:38 PM
tuned out's Avatar
[QUOTE=Tuned Performance;6521138]Fuel pressure tested ? Original multec injectors ?
hot spark ? Has the car sat for along time?[/QU]
it runs off starting fluid, I haven’t tested with a noid light. I’ll need to buy one of those. Not sure if original injectors.
it clearly sat for a long time
Old Jan 3, 2024 | 08:42 PM
Engine: Lb9
Transmission: M20
Even though fuel pump is new it could be tbi low pressure. Might wrong not defective .double check it.
if fuel pressure and injector pulse with a noid light. Contact southbay fuel injectors for a set of injectors. Stock grey body injectors fail over time with coil shorting. If the car has sat for years injectors stick shut.
Old Jan 3, 2024 | 08:53 PM
tuned out's Avatar
thank you
rarebmx
May 20, 2015 01:11 AM
duckslayer500
Jul 21, 2013 04:02 AM
orangek
Jul 17, 2013 02:46 PM
diverdave
Jun 21, 2011 10:39 AM
bdennis1983
Jul 16, 2010 03:14 PM
