Speedometer issue
Old Feb 3, 2024 | 05:53 AM
84maroguy's Avatar
Car: 1984 canaro
Axle/Gears: 3.08 ratio
Speedometer issue
I have a duel needle that goes crazy and maxes out even at 30, it won’t go back to normal till I stop…could this be a cable or issues with the speedo gears in the cluster?
Old Feb 5, 2024 | 02:15 PM
KITT87's Avatar
Car: ‘87 Base Firebird
Engine: 2.8 V6
Re: Speedometer issue
I can’t speak for the dual needle, but the cable driven speedo on my ‘87 base bird was bouncing all over the place and squealing until I replaced the cable. You could potentially just grease the cable if it’s in good enough shape. Good thread on mechanical speedo stuff here
Old Feb 5, 2024 | 04:35 PM
"Dual needle" doesn't matter in the slightest.
Greasing the cable is absolutely a good place to start.
Does the car have cruise? If so, the module (regulator) may be fornicated, and need replacement.
Old Feb 6, 2024 | 07:13 PM
84maroguy's Avatar
Car: 1984 canaro
I do not have cruise control
Old Feb 6, 2024 | 08:20 PM
Then lubing the cable is the best thing you can do right now. No guarantees, but, start there.
Old Feb 13, 2024 | 11:42 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Some early cars (double needle speedo) used a 2-price speedo cable, and the early cars (82-83 I think) used a cruise module the speedo cable plugs into. These are obviously more complex to diagnose than later 1-price style speedo cables. (84/5+ speedo cables)
i’d start at the tranny end; It’s very possible that the speedometer gears inside the tranny have worn. ( usually the one on the tranny tail shaft) It’s quick and pretty easy to pull the speed sensor out to inspect both the plastic gears. While it’s apart you can spin the cable with your fingers to feel for any ‘binding’.
if you have to replace the cable,…. Get a 1-price !
RWO3
Feb 15, 2012 02:33 PM
beckler
Sep 16, 2011 05:22 PM
chixon
Nov 26, 2007 10:52 AM
Pumpin306
Jun 3, 2007 11:04 PM
