Intake corrosion - how much is too much?
Old Mar 27, 2024 | 10:04 AM
gw204's Avatar
Pulled the intake on my son's carbed '86 Firebird because of evidence of coolant leaks at the driver's side front and pass side rear. I was expecting some corrosion but once I got it cleaned up, things look worse than what I was expecting. My gut says to ditch this manifold and source a replacement, but I wanted to get some additional opinions first. I know it can be hard to tell from a picture, but this is the pass side rear...
I was planning to supplement the new gasket with a little RTV, but I think this one is just too far gone...and I don't want to risk having to do this job twice. Thoughts?
Thanks!
Old Mar 27, 2024 | 10:18 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Intake corrosion - how much is too much?
I think that could be sealed effectivly,but if a better condition intake is handy,use the better one which engine BTW?
Old Mar 27, 2024 | 10:29 AM
gw204's Avatar
Originally Posted by 8t2 z-chev
which engine BTW?
Sorry. 305 w/ Quadrajet.
Old Mar 27, 2024 | 11:17 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
That should seal up with RTV. I would use enough that it squeezes out a little when you tighten, then wipe excess off with towel. There are purists on here that despise such things, but I guess they are rich.
Old Mar 27, 2024 | 01:43 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
That looks bad, and it's apart because it was already leaking......
Weigh the time and effort involved in doing the job twice with sourcing a replacement and doing it once.
Old Mar 29, 2024 | 01:20 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
IMO: Toss it and buy a new (- or a good / quality used ) intake.
Sure; I’m betting you’ll get it to seal, but when it leaks it will leak there first and the more it runs the sooner it will leak. Coolant in the crankcase is a bitch,…. Why risk it when a cheap replacement intake installed now completely avoids the problem.
just my
Old Mar 29, 2024 | 09:26 AM
Vader's Avatar
It COULD seal if a lot of cleaning is done. It's difficult to determine from the photo, but the depth of the corrosion might even require machining. I've had the same condition on some 60° V-6 engines with aluminum heads and intakes, and managed to make then seal. Some have needed etching, epoxy filler, then machining flat. At that point, a different intake may be more economical.
Old Mar 30, 2024 | 09:54 AM
gw204's Avatar
Thanks for the feedback guys. Decided to ditch it and was able to source an Edelbrock 3701 locally.
Bohemian
Apr 17, 2022 10:07 PM
mr_han_solo
Feb 11, 2016 11:49 PM
apie2546
Jun 27, 2015 08:56 PM
randomdguyd
Carburetors
Jun 10, 2009 07:31 PM
camaroguy99
May 6, 2002 11:11 PM
