Diagnosing Fuel pump and sender
Old Jun 12, 2024 | 11:22 AM
89 formula TPI's Avatar
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
Hey guys,
I have an 89 Firebird Formula 5.0L TPI (VIN code F). After a few years of sitting in storage my car developed two issues:
1) the fuel gage is constantly pegged above full
2) the fuel pump is dead
I tested my fuel sender by hooking up a multimeter to the harness coming off the fuel tank, set to ohms, and probed the Pink and Ground, I got a reading of .34 ohms, which makes sense since I put about 5 gallons in and the range is 0 (empty) to 90 (full) ohms. I tested the side coming from the dash for power by probing the Tan and ground and got 9.5 volts. A little low, but I assume this was because my battery has been on a trickle charger. This leads me to believe my gage and not my sender is the problem. Would you guys agree?
I tested my fuel pump by checking the fuse under the dash, also the one in the engine bay by the battery and both were good. I tested the Fuel pump relay by removing the cap and turning to the key run, I watched the relay snap shut for 2-3 seconds then open. I also applied 12v directly to terminal G of the ALDL. The fuel pump didn't make any noise. And finally, I have 0 fuel pressure at the fuel rail. Am i missing anything or can i assume i have a dead fuel pump on my hands? Looking for some additional confirmation before I go dropping the tank.
And thank you to everyone who contributes to this site, it was the only way I was able to research the procedures to even test this stuff.
So to summarize, do you guys agree I have a bad fuel gage and dead fuel pump on my hands? Can anyone recommend a fuel pump and sending unit? I am having trouble finding an AC Delco and I'd like to stick with OEM. If not, i've heard spectra mentioned a few times, any other suggestions? Ideally i'd like to find the whole pump/sender assembly
Old Jun 12, 2024 | 06:37 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Diagnosing Fuel pump and sender
is the sender grounded?
Old Jun 13, 2024 | 08:06 AM
I believe so, I probed the Pink and ground coming off the harness from the tank with the continuity setting and got continuity on my meter. That would confirm it's good, right?
Diggler86
May 1, 2024 11:00 AM
92rsreed
Mar 21, 2016 12:23 AM
cal30_sniper
Nov 25, 2012 05:35 PM
ERICSCHEVY
Jul 15, 2009 04:44 PM
smiley23
Apr 15, 2004 09:21 AM
