[305 TPI] Car runs terrible after replacing injectors (very rich?)
Old Jun 15, 2024 | 07:56 PM
SkiingOnIce's Avatar
Hi all,
I think my old injectors were leaking, since I was having hard starts when the car was warm. The injectors in the car were Bosch 0280 155 771 (EV6 CL?) injectors. This site (https://www.injectorplanet.com/produ...-ford-f73e-b5a) lists them at 18.1 lb/hr, which I think is leaner than the recommended 19lb/hr for this engine. I replaced them with these 19lb/hr supposedly-compatible injectors (https://www.ebay.com/itm/354844107544) which were rated for 19lb/hr and listed by the seller as compatible with the 305 TPI. I'm guessing they weren't, since the car now runs like a boat belching black smoke out the back and can't hold idle.
What are the details you look for to determine whether fuel injectors are compatible with your vehicle? Clearly the seller info isn't trustworthy in this case. Are injectors something you can swap and expect to run? Or do they always require some kind of ECU tuning to make work?
Old Jun 15, 2024 | 08:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: [305 TPI] Car runs terrible after replacing injectors (very rich?)
So you bought a set of 8 injectors for less than the price of one good quality one.
no wonder it runs like crap
Old Jun 15, 2024 | 08:30 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
https://www.southbayfuelinjectors.co...d-305-tpi.html
No need to look for details, just put the Delphis in from Southbay and it'll be good.
Old Jun 15, 2024 | 08:54 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
No he paid $262.48 plus TAX for 8 injectors and it runs like crap.
EDIT: Man I didn't read that eBay ad well. OMG a set of 8 for $33.82. Jesus H Christ what did he expect?
Last edited by Airwolfe; Jun 16, 2024 at 09:32 AM. Reason: I'm an idiot that can't read!!! LOL
Old Jun 15, 2024 | 08:55 PM
Engine: Lb9
Transmission: M20
https://www.southbayfuelinjectors.co...-firebird.html
even these are a good option
Old Jun 15, 2024 | 08:57 PM
ULTM8Z's Avatar
Those cross reference to Ford FOTE-D5A. Evidently 20 lb/hr @43 psi.
So they're already ~5% bigger than the factory 19 lb/hr. Plus potential issues with the voltage offsets in the PROM calibration...
Then the variable of dealing with Ebay sellers... (who knows what it is they're doing with these things).
As was said earlier, probably get some Delphis if you don't want to deal with calibration issues.
Old Jun 16, 2024 | 01:29 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Should have bought the additional $7.99 protection plan from Allstate.
Old Jun 19, 2024 | 01:26 PM
Thanks for the ID. I was able to get a refund from ebay since these injectors were incorrectly listed as 19lb/hr rather than 20lb/hr
Also, I guess my big remaining question is whether you need to re-tune the ECU after replacing injectors that are the same flow rate as the old ones. The other threads I've seen on this forum mention having to change "offsets" and timing things in the computer? Or is that only if you're changing the flow rate with the new set of injectors?
Old Jun 19, 2024 | 01:37 PM
Engine: Lb9
Transmission: M20
Unless the injectors have major differences in flow and voltage offsets you will be fine without tuning. Get the ones linked on post 5 or delphis. Amazon and for the most part eBay is not the place to shop for injectors.
Old Jun 19, 2024 | 07:00 PM
ULTM8Z's Avatar
I would make it easy on yourself and just call SouthBay Fuel Injectors. Tell them what you want and they'll get you set up with quality stuff.
Old Jun 19, 2024 | 08:24 PM
southbay's Avatar
Hey...just saw your post. Sorry you're having issues with injectors. give us a call. We'll be more than happy to help you. Unfortunately there is one glitch....the delphi injectors have been on backorder for the past few months. Not sure when we will be getting them in
Old Jun 20, 2024 | 05:11 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I've been watching that, need a set of 22s
Old Jun 27, 2024 | 11:01 AM
Thanks for the into everyone. I decided to increase my budget to a blistering $60 for the set, and installed these refurbs also from ebay https://www.ebay.com/itm/293746120349
Also was able to get a full refund for the set that was 20lb/hr, since they were incorrectly described. Ebay has a great warranty process for auto parts.
I installed them in the engine and they work great! Warm starts are successful, no leaks, idles smooth as glass. The injector part number was 0280155771. The manufacturer part is FJ310, which I think are injectors made by Standard Motor Products. Hopefully that part number is generally the correct one to use for 305 TPI engines
Old Jun 27, 2024 | 11:08 AM
ULTM8Z's Avatar
glad you got it resolved. I can understand trying to keep costs down in today's economy.
Old Jun 27, 2024 | 11:11 AM
Engine: Lb9
Transmission: M20
Hopefully they last, seems way to cheap for China injectors for them to actually work well and last.
Old Jun 27, 2024 | 01:39 PM
southbay08's Avatar
just my 2 cents. Be very careful what you buy on ebay. Each of those injector is $7 ea. That's a red flag. If you look on the injector there are no part numbers. I'm not telling you this because I'm trying to get you to purchase from us.... that's not my intention at all....Just a little insight. We clean and flow many injectors that appear to be from china ...they flow all over the place. Especially when we flow them dynamically. However there are plenty out there that work totally fine.
The part number 280155771 is a cream colored injector...it's an actual core this injector is blue. Anyway I hope they work well for you and they solve your problem
Old Jun 27, 2024 | 02:22 PM
TTOP350's Avatar
Any idea when the 22lb delphi will be back in stock?
Old Jun 27, 2024 | 03:16 PM
southbay08's Avatar
As a matter of fact I'm hoping they will be in by tomorrow or monday. I was going to contact you however i wanted to have them in my hands first
Old Jun 27, 2024 | 07:47 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Glad they are working good for you. I too understand needing to save money where possible.
I researched that Ebay seller and saw a lot of negative reviews, many of which had to do with low quality injectors and some noting they were Chinese knock-offs.
I went with the Southbay Delphis on my L98 a few years ago and have been very happy with them. It was money well spent.
Old Jun 27, 2024 | 08:03 PM
ULTM8Z's Avatar
I also went with them on some injectors for a special project I was working with on my Miniram 383. They helped me do the research on what I needed then supplied the injectors at a very fair price. Very high quality products.
Old Jun 28, 2024 | 04:36 PM
southbay08's Avatar
DELPHI'S ARE BACK IN STOCK!!!
Engine: Lb9
Transmission: M20
Yeah !!!!
TBI92Camaro
Jul 1, 2014 07:32 PM
wager420
Jun 20, 2011 07:22 AM
xlwhellraiser
Sep 18, 2006 12:17 AM
Jerriko 3.4
Oct 25, 2004 10:42 PM
Scottlb9
Sep 14, 2004 08:00 PM
