Factory AC Wiring questions
Old Jun 17, 2024 | 12:27 AM
87irocz28350's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 open
I have a new to me 89 RS that has factory AC. The blower motor works, the system appears to have charge, but AC does not work as the compressor does not engage.
When I started looking into it, the wiring seems to be the reason. The low pressure switch is wired to ground, and there is some sort of aftermarket relay situation wired into I believe the AC wiring. I intend to reset to factory wiring, but I have an issue:
I have attached the schematic for reference. It appears that there should be a LT Green wire coming from the AC controls in the car, to the low pressure switch. Where might I find this wire?
The wire then leaves the low pressure switch, and continues on to C105. C105 appears to be on the firewall, near the blower motor box. That sound correct?
Old Jun 17, 2024 | 10:47 AM
Re: Factory AC Wiring questions
In the AC harness, which emerges through the firewall near the heater hoses.
That sound correct?
​​​​​​​Close: it's right above the pass side valve cover. Has some number of green wires (1 or 2), a Big Red one, and maybe an equally big black one.
BlueMagicSS
Feb 25, 2026 10:57 AM
nickgoesfast
Sep 25, 2021 05:02 AM
TKO500
Jan 29, 2020 07:32 PM
CMAN84
Jan 26, 2017 03:45 PM
BigWhiteGTP
Mar 22, 2005 08:54 AM
