AC Wiring Assistance - 91 Camaro LS Swap/3rd gen HVAC
Old Mar 2, 2018 | 08:09 AM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
After searching a number of threads and did not find guidance around my specific configuration, although I am sure it exists. Feel free to point me in the right direction or post up the specifics.
I have a LS in my 91 Camaro and preserved all of the the factory HVAC components (wiring, relay, compressor, etc). My goal is to integrate this into the existing LS configuration.
Current components are:
            Looking for guidance on how exactly to functionally wire the HVAC.
            Attached Thumbnails AC Wiring Assistance - 91 Camaro LS Swap/3rd gen HVAC-img_3392.jpg   AC Wiring Assistance - 91 Camaro LS Swap/3rd gen HVAC-img_3393.jpg
            Old Mar 2, 2018 | 11:59 AM
            6speedIROC's Avatar
            Car: 86 IROC
            Engine: LQ4 6.0L
            Axle/Gears: 3.55 8.8
            Re: AC Wiring Assistance - 91 Camaro LS Swap/3rd gen HVAC
            Check out my wiring diagram for how mine is set up..
            https://www.thirdgen.org/forums/ltx-...-pcm-into.html
            Old Mar 3, 2018 | 11:43 AM
            kenney001's Avatar
            Car: 1990 Iroc-Z
            Engine: 5.7 TPI
            I have exactly the same setup. I bought another oval relay and put it on the extra relay mount next to the blower motor. Wire it like this:
            Note the purple doesnt HAVE to go to IAT. It's either a ground or 5v reference I cannot remember, nothing specific to the IAT
            I also ditched the low pressure switch on the dryer
            Old Mar 9, 2018 | 11:15 PM
            TKO500's Avatar
            The diagram shows integrating the wiring with the PCM. I would prefer allow it to function as a standalone system and integrate the AC request wire only.
            Is this a possibility?
            Or am I forced to wire it as noted in the above diagram?
            Old Mar 10, 2018 | 12:33 AM
            88Greg's Avatar
            Car: 88 Trans am
            Axle/Gears: C4 IRS 3.42
            Depends if you want the PCM to bump the idle _and_ turn rad fans on.
            Old Jan 29, 2020 | 06:37 PM
            eduardosac's Avatar
            Car: 1990 Iroc-z
            Engine: LS3/LSA blower
            any luck on figuring out how to make the compressor work off of single wire
            Old Jan 29, 2020 | 07:32 PM
            scooter's Avatar
            Car: 92 Firebird
            Engine: 4.8 LR4
            Axle/Gears: 3.45 9 Bolt
            Just leave it wired like the stock TPI if you want, then have the clutch command wire connected to the LS ECM so it knows the air is on
            Damien00677
            Mid-West Region
            Feb 20, 2012 11:16 AM
            multi-tasking
            Mar 28, 2011 07:38 PM
            Demo77
            Jul 30, 2010 10:46 AM
            maroman88
            Oct 6, 2008 12:44 AM
            FlamedROC
            Dec 26, 2004 01:38 PM
