TPI to carb charcoal canister hookup?
Old Jul 4, 2024 | 03:43 AM
leakyz28's Avatar
Car: 88 IROC-Z
Engine: 350 H.O. w/ 113 heads (SUM-8800)
Transmission: 700r4 stage 2 500hp
Axle/Gears: 2.73 Posi Yawn Fest
Hey guys, I recently did my swap and decided to swap to a carburetor with my crate motor however I kept the ECU to retain the in tank fuel pump and possibly the TPI charcoal canister functionality, my question is will my TPI charcoal canister work with the carbed setup as long as I keep the ECM running? right now I have the line on the top hooked to full manifold vacuum. I heard these things are very useful to have in terms of fighting stinky car syndrome and can even lead to a 10% increase in fuel economy, pretty cool!
Old Jul 13, 2024 | 12:14 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: TPI to carb charcoal canister hookup?
I am by no means an expert with the fuel systems in the later models, and I don't know what scheme of evap the EFI systems had (partial vacuum, switched vacuum, self testing ect) That being said, you should be able to run full manifold vacuum from the carb or intake if the carb does not have a port to the purge solenoid and the system will function normally if the ECU does not disable evap functions when in a fault mode (it will certainly have faults when it sees ignition power but no fuel injectors, to say nothing of any other components).
rm1sner
Carburetors
May 1, 2012 03:00 PM
ATCFLYBOY02
Carburetors
28
Jan 18, 2012 05:49 PM
camaroz2887
Oct 16, 2010 01:06 AM
boa34b
Apr 22, 2005 07:40 AM
HondaHunter
Oct 24, 2001 02:24 PM
