383 sbc camshaft
Old Aug 14, 2024 | 11:47 AM
Dave Keefer's Avatar
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
383 sbc camshaft
Hope someone has an answer for me please, I’m currently building a sbc 383 and found a new camshaft that was supposed to be in a factory Gm 383. Pert number 19210723. It was supposed to be a factory pull out as the engine builder wanted something different. Upon closer inspection there appears there are no part numbers on it. I thought that was pretty unusual for a Gm camshaft. The only id I see is it’s marked with blue paint! Can anyone comment or confirm . Thanks
Old Aug 14, 2024 | 12:55 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: 383 sbc camshaft
No. Not without numbers.GM never made a factory 383.
Old Aug 14, 2024 | 01:09 PM
Well, they kinda do... it's available as an over-the-counter crate motor. You're right though that none ever came in any vehicles. And, GM's 383 isn't exactly the same as one we might build; instead of the typical stock 400 stroke, its is slightly longer, which is how they get a 383 out of a 4.000" bore.
Last I knew GM was getting most of their cams of that general sort from Crane.
If you research the "HT383" you might be able to get some specs.
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I just checked the 2024 Chevy Performance Parts Catalog. 19210723 is the cam part number listed for their "SP383 Turn Key" complete motor. It is shown on page 140 of the catalog. The cam specs are listed as follows:
Hydraulic roller
Valve Lift (in): .509 intake / .528 exhaust
Camshaft Duration (@.050 in): 222° intake / 230° exhaust
As SofaKingdom said, Crane made Chevy's performance cams. I checked a 2013 issue of the Crane Master catalog and found part number 109831. The specs match the Chevy cam and also lists the following: Lobe Separation Angle: 112 Degrees, RPM Range 2000-6000, Fair Idle.
One interesting note is that the HT383 is listed with a different cam as follows:
Camshaft Type (P/N 14097395): Hydraulic roller
Valve Lift (in): .431 intake / .451 exhaust
Camshaft Duration (@.050 in): 196° intake / 206° exhaust
Fred
Last edited by Fred SS; Aug 14, 2024 at 01:52 PM. Reason: Add allot more info and correct error
Old Aug 14, 2024 | 02:03 PM
Axle/Gears: 370
I do believe Gm made an aftermarket 383 . Aftermarket ps like summit offer several different cubic inches.
Old Aug 14, 2024 | 02:07 PM
Axle/Gears: 370
Thanks for checking for me ! The guy I bought it from swears it’s a383 sbc with that number. Still I’m questioning the no part number?
Old Aug 14, 2024 | 02:26 PM
Fred SS's Avatar
Transmission: 2004r
You could install it in your block then degree the cam to determine the specs. .509/.528 Valve Lift comes to .339/.352 Lobe Lift with 1.5 ratio rockers. The Chevy and Crane catalogs both say 1.5 ratio rockers.
Hope this helps,
Fred
Old Aug 14, 2024 | 03:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Easiest way to know if it's a 383 without stripping it down to check part numbers on the crank and rods is to look at the balancer and flywheel/flexplate. Unless GM decided to use an internally balanced crankshaft in their non production 383 engines, they will be externally balanced just like the 400 engines use using external balance weight. The end of the crankshaft will also have a dowel so that the balancer/flexplate can only go on in one position.
There's nothing saying GM used internally balanced cranks to make their 383 engines either.
Old Aug 14, 2024 | 05:22 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The last 4 digits of the part number will be stamped on the rear end of the camshaft. The SP383 has a GM supplier clone of the old Crane made GM 846 cam.
12370846 Hydraulic Roller Design
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 222/230; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 509/528. Valve lash is zero/zero and lobe centerline is 112 degrees.
14097395 cam from a 2017 GM built HT383 Mercruiser boat engine. The HT383E balancer uses a bolt on counterweight and all 1-piece rear seal small blocks are externally balanced on the rear.
Old Aug 14, 2024 | 05:37 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
HT383 balancer is a 12498008. Counterweight is bolted on.
Old Aug 14, 2024 | 06:16 PM
ULTM8Z's Avatar
I have the HT383 short block.
On the back of the engine in the bellhousing area, it has this ID tag...(picture 1 below)
It also came with the SP383 cam. There was no p/n on the cam oddly enough, but Scoggin Dickey Chevrolet (where it came from) said it was the SP383 cam, and I also verified it against the specs on that cam with the degree wheel. The only markings on the cam were V119 216 (picture 2 below)
Also, the only 383 that GM ever built was crate engine that uses the mid-90's Vortec blocks with the composite timing cover. If its not a Vortec block, it is not a GM 383.
But you can also measure the stroke... it should be 3.800 (not 3.750). That 3.800 crank is a unique GM crankshaft.
Old Aug 14, 2024 | 07:31 PM
Axle/Gears: 370
Hope this helps,
Fred
thanks that’s a great idea and exactly what I’ll do !!! I appreciate the suggestion.
Old Aug 14, 2024 | 09:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have never seen a GM cam that did not have numbers somewhere on it. Most of the GM performance cams are marked on the rear of the cam. Some are between the fuel pump eccentric lobe and #1 exhaust lobe.
Old Aug 14, 2024 | 09:16 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Literally googled the cam in question. Found a picture with the last 4 of the part number right on it.
Johnny Blaze
Jun 25, 2005 12:51 AM
Orizon
Oct 22, 2004 11:34 PM
killerIROC
Dec 9, 2003 12:07 AM
demon138
Jul 11, 2003 04:46 PM
Pete 85 Z
Mar 31, 2002 08:37 PM
