(HELP) 89 Camaro 305 Tbi starting issue.
Hey y'all first post but I need some help. I have a 89 Camaro 305 TBI but I’m currently trying to figure out my starting issue. The car does run but not till it builds oil pressure also the Fuel pump doesn’t turn on till oil pressure builds. The fuel pump relay has never clicked on before old or new.
I’ve replaced (Fuel pump) (Fuel lines) (Fuel pump relay) and some wiring and all fuses are good
I do have a suspicion it’s a wiring issue because the person that owned the car before me hacked all of it up.
Any help is greatly appreciated Thank you.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: (HELP) 89 Camaro 305 Tbi starting issue.
Is there voltage at the fp relay green/white wire at pump prime ?
ir0cz
Apr 3, 2002 06:34 PM
