84 trans am engine woes
Old Sep 6, 2024 | 05:13 PM
benh's Avatar
Car: 84 trans am anniversary edition
Engine: Mutant
I bought a 15th anniversary edition trans am and have started the process of restoring it to roadworthy condition. Started tearing down the engine and found rust on the crank and lots of rust particles in the oil pan.
I started noticing some things that had obviously been modified. The pistons had 2 valve reliefs instead of 4, I believe they are .030 over, and the cam was a high energy comp with a double roller timing chain. The dipstick is on the driver’s side too, and everything I look at says it should be on the passenger side.
I started digging into casting numbers and this one is 460778, which shows to be a 78-79 block. I’m assuming it had an engine swap at some point? If it’s not the original block then just build out a 350 block to a stroker?
Any opinions?
Old Sep 6, 2024 | 06:32 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 84 trans am engine woes
that is an odd one -looks like 305 bore size,but there is a 400 crank damper...Someone my have built a 334 305 stroker...
Old Sep 6, 2024 | 06:56 PM
benh's Avatar
Engine: Mutant
Guess I’ll find out soon enough. Gonna pull it this weekend and see what the damage is. There is some carbon buildup at the top of the cylinders so my measurements aren’t true, but they are measuring out 3.745.
Old Sep 6, 2024 | 09:00 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
I always thought 334s were odd, but they done some around the early 1990s. Close to "square" engine-bore and stroke about the same dimension. RH dipstick started with 1980 production SBCs,so that is an early 305 block.
Old Sep 8, 2024 | 06:03 PM
benh's Avatar
Engine: Mutant
So I confirmed that it does have a stroker crank and what look like .030 over Keith Black pistons with eagle rods and ARP rod bolts. I’ll try to get it out sometime this next week and get it to a machine shop for inspection and cleanup. Hopefully most of it will be reusable.
panthor
Oct 4, 2023 08:48 PM
jnota
Jan 13, 2023 09:03 PM
thainglo
Mar 12, 2022 07:52 PM
TKO500
Dec 16, 2017 03:21 PM
84LS creeper
Feb 18, 2002 05:49 PM
