intermittent starting issue
Old Sep 17, 2024 | 10:44 PM
flippedtable's Avatar
Car: 92 RS
Engine: 305tbi
92 rs 305tbi, randomly some days will not start then it will a hour later, I hear fuel pump and have power to the dash but the starter/ignition doesnt even try. i see stuff about vats but not a clear direction to remove it or possibly the ignition rod/cylinder? any tips would be appreciated.
Old Sep 18, 2024 | 10:35 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: intermittent starting issue
What have you tested ? Spark when hot , fuel pressure? Injector pulse ?
Old Sep 18, 2024 | 10:51 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I don't think it's CRANKING.....
OP can you confirm that it won't crank when the problem is happening? If that is the case, I'd get a test light or DVOM and start at the starter and work my way back through the starting circuit. It could be as simple as a corroded ring connector on the starter.
Does the car actually have VATS? If so, do 3rd gens have a "Security" light on the dash? If so, what's that light doing when you have the key in/turned to the "run" position?
Old Sep 18, 2024 | 11:16 AM
Engine: Lb9
Transmission: M20
Gotcha, jumper the starter enable relay see if it cranks then
Old Sep 18, 2024 | 09:43 PM
Car: 92 RS
Engine: 305tbi
yea it wont event try to. i hear the fuel pump have power everywhere but when turn the key nothing happens. CEL and Security light will be on. replaced starter other day because I figured that was the issue but looking into it more it seems like the vats system or the wires inside the column are the issue.... i went ahead and ordered the resistor kit off ebay to just bypass the vats system so if that doesnt work reliably i know its probably something else. it cranks when hot, cold etc but its just at random when it does this issue.
Old Sep 19, 2024 | 09:13 AM
Engine: LT1, L400
Here is a quick read to clarify the value of the "SECURITY" light...and thus, the likely hood of YOUR issue being a VATS issue, or something else:
Al Nonymous
Jul 20, 2015 01:02 AM
thizzlamich
Apr 1, 2013 08:41 PM
91TA
Sep 19, 2002 07:52 PM
Mutiny32
Mar 17, 2002 10:33 AM
Black Beauty
May 15, 2001 11:53 PM
