With 2 breathers and no PVC
Old Sep 19, 2024 | 06:03 AM
miche25's Avatar
Car: Camaro 1984
Camaro Z28 1984 - trans. man. - Rochester - Camed. My car always had a tendency to give small jerks at low revs.
I changed the pcv twice, it didn't change anything, I plugged the PVC inlet line to the carburetor and I put a free pipe (without PVC) at the outlet of the valve cover.
Since then my engine runs much better and acceleration is better. I thought of putting a second breather (no PVC).
One on the left and one on the right of the engine.
Question: Does it have a risk for my engine?
Old Sep 19, 2024 | 01:11 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: With 2 breathers and no PVC
there will be greater tendency for oil contamination (moisture,fuel) over time without the PVC- SBCs prior to about 1968 did not have pvc-just had that big oil fill pipe with breather cap at front of intake manifold
Old Sep 19, 2024 | 01:48 PM
miche25's Avatar
Car: Camaro 1984
Thank you,
In this case, there will be no risk of creating bad pressure in the crankcase?
NZKnight
Oct 15, 2015 02:47 PM
85CAMAROCC
May 15, 2005 02:41 PM
camarodragon
Jan 11, 2005 05:35 PM
cunawarit
Jul 15, 2003 07:31 PM
