No Crank. Not sure why..? Help Please!
Old Nov 9, 2024 | 02:19 PM
91Camaro17's Avatar
Car: 91 Camaro
Engine: 305 TBI
What's up, everyone. I have a 91 camaro 305 TBI with Auto Trans. Here's my problem, I turn it on, I have power, and everything seems to be working fine. When I go to start it. The starter comes out to engage, but the engine won't crank and I dont know why.
I have replaced the Battery, Starter, Starter Relay, Ignition Switch, Plugs, Wires, Cap, Rotor, Ignition Control Module, Coil, Map Sensor and Bypassed the VATS System. I also did a rebuild to the Throttle Body.
I will say I started this about 2.5 years ago. I fired it up pulled it out of the garage turned it off and a couple hours later. This is what's been happening.
Thanks in advance.
Old Nov 9, 2024 | 02:29 PM
Re: No Crank. Not sure why..? Help Please!
Can you turn the engine by hand? DO NOT attempt to do this with the crank damper bolt: use something like a belt or chain wrench around the damper.
Old Nov 9, 2024 | 06:06 PM
91Camaro17's Avatar
Car: 91 Camaro
Engine: 305 TBI
No I have not tried that yet. Probably should've started with there. I will get back to you once I've done that. Thanks for the response.
felon
Jun 27, 2024 04:17 PM
BlueBomber22
Feb 22, 2022 05:25 PM
IndyRiver
Feb 6, 2014 11:55 PM
camario
Dec 20, 2011 10:17 PM
thebandit92
Apr 2, 2008 12:36 PM
