Broken Bolt Size Intake Manifold
Old Jan 15, 2025 | 08:16 PM
pete2833's Avatar
Car: 1986 Camaro Iroc
Engine: 5.0 TPI
I was removing the fuel rail to replace injectors and I tried working a bolt out and it snapped.
Bolt is on the front of the lower intake manifold. It is the bolt that holds the bracket to the manifold with the fuel lines going to the rail.
Front of manifold just below the thermostat housing.
Need to drill it out and retap.
Any one know the size of the original bolt ? That way I can drill the appropriate hole to retap.
The pic isn't my manifold. Just a pic for an example.
Thx !
Old Jan 15, 2025 | 09:10 PM
Re: Broken Bolt Size Intake Manifold
Should be 3/8"-16 like all the other accessory bolt holes on a SBC.
Use a Heli-Coil of the correct size. DO NOT hallucinate that drilling it out larger to some weird size is A Good Idea. It's NOT.
Old Jan 16, 2025 | 04:52 AM
pete2833's Avatar
Engine: 5.0 TPI
Thanks. I also contemplated finding the same intake and replacing it. I will probably have to remove it to tap it. Can’t get a straight shot with a drill.
Old Jan 18, 2025 | 03:53 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Yes, it is 3/8"-16.
gruveb
Mar 28, 2003 07:42 PM
CamaroEFI
Jul 28, 2002 05:56 AM
MikeH
Apr 17, 2002 04:04 PM
