Pontiac fiero
Pontiac fiero
I have a 87 Pontiac fiero with a 2.8 l engine I took a 2006 Pontiac G6 3.5 l block bolted my 2.8 l heads and intake on it put my distributor in it it runs but it makes the manifolds glow red what could be the problem
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Pontiac fiero
Late ignition timing could cause that-you might get more response on a Fiero forum,but the 60* v6 is known around here
Car: 1985 Z28
Engine: 305 LG4
Re: Pontiac fiero
It MIGHT have something to do with bolting 1987 2.8 heads onto a 2006 3.5 block, and presumably all the 2.8 fuel components designed to feed a 1987 2.8 engine. I had no idea this was even possible, and the mere suggestion is enough to make me cringe. Good luck with all that, you have bolted together an interesting mess.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Pontiac fiero
You need to be on a forum dedicated to the Pontiac Fiero & GM's 60 Degree V6 engines.
There are many threads about what you want to do on these forums.
Fiero - Pontiac's Mid-Engine Sportscar
Pennock's Fiero Forum
60DegreeV6.com
