Baffled Grommets
Old Apr 6, 2025 | 02:54 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Baffled Grommets
hey all, I'm trying to sort out PCV sucking up a load of oil. I want to try baffled grommets but it's tricky to know what to get? I need one for PCV and the other for the passenger side elbow. Does anyone know exactly what to go for?
https://www.summitracing.com/parts/mor-68772
Old Apr 6, 2025 | 03:17 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Re: Baffled Grommets
How about, measure the crankcase pressure first to see whether its blowing oil out or not
Set the crankcase pressure negative at wot/cruise/idle, like an OEM engine
then it will suck oil in, instead of blow it out
Old Apr 6, 2025 | 04:36 PM
NoEmissions84TA's Avatar
Competition Products
type valve cover grommet in the search box
Power Products, Valve Cover Grommet, 3/4" ID, w/Baffle, PCV, Each - Competition Products
Power Products, Valve Cover Grommet, 1" ID, w/Baffle, Breather, Each - Competition Products
Old Apr 7, 2025 | 02:51 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks, this is perfect
xxpotandaxx
Aug 7, 2010 05:50 PM
noboostnogo
Jul 17, 2009 10:00 AM
LCC.GTA
Apr 15, 2008 01:01 PM
R4][N_M4l{3R
Apr 23, 2006 04:13 AM
TransAm12sec
Mar 16, 2003 10:39 PM
