Switched ignition source in engine bay locations?
Old Apr 30, 2025 | 08:01 AM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Hi all,
I'm looking for a good, switched ignition source in the engine bay to hook up an electric fan controller.
Amazon.com: EXMIATOV Digital Radiator Fans Controller Swith,12V and 24V Adjustable Temperature Range Digital Electric Thermatic Fan Switch Kit Compatible with Davies Craig 0444 : Automotive Amazon.com: EXMIATOV Digital Radiator Fans Controller Swith,12V and 24V Adjustable Temperature Range Digital Electric Thermatic Fan Switch Kit Compatible with Davies Craig 0444 : Automotive
Can anyone recommend a good place to tap into in the engine bay? I'm trying to not have to run wiring any further than needed.
Old Apr 30, 2025 | 11:31 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Switched ignition source in engine bay locations?
Pink wire at the ignition coil is hot in run/start
Old Apr 30, 2025 | 11:55 AM
t/adreams's Avatar
Car: '91 Trans Am
Axle/Gears: 3:42
Thank you!!
bminnix
Jul 3, 2010 10:16 AM
killer89ta
Apr 3, 2006 02:39 PM
Firebird1984
Mar 24, 2006 11:02 PM
spartyon
Oct 19, 2002 12:17 PM
fattie92
Mar 25, 2002 08:47 PM
