Balancer.......stud?
Old May 13, 2025 | 10:37 AM
Andreas_91GTA's Avatar
Car: Trans Am GTA 1991
Engine: L98 with Super Ram and Fitech
Axle/Gears: 3.23:1
Why on earth do I have a balancer stud instead of a regular bolt? Is this some home-brewed black magic solution?
I want to take it off. The first threads got damaged by my puller. I can of course cut the first 3-4 threads off but that will be a hassle.
(yes, the drop of blood on the floor is from me. cut myself on those broken threads)
Old May 13, 2025 | 10:42 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Balancer.......stud?
That should unthread.
Old May 13, 2025 | 10:48 AM
Axle/Gears: 3.23:1
Definitely, but good luck to me keeping the crank still while cranking on that stud.
Old May 13, 2025 | 10:53 AM
Why on earth do I have a ...
You're asking US why some ... HUMAN ... did something STUUUUPID and/or weird??? How the hell are WE supposed to know what going going through their mind at the moment? (besides a breeze)
That's about as good an explanation as any. Although "solution" is probably a little too enthusiastic of a description.
Although actually, a stud and a nut is probably a decent enough idea, IF EXECUTED CORRECTLY. Like, if it didn't leave about half a meter of threads sticking out the front.
All that aside: cut it off to clean threads, or run a die down over it; put 2 nuts on it, and tighten them together real good; and back it out with a wrench on the rear one. A pipe wrench on the crank, applied GENTLY, will hold it still. Easy enough to replace the Woodruff key if it gets damaged.
That's almost certainly the wrong timing mark for the crank damper you have, although I'm sure you've already figured that out.
Old May 13, 2025 | 11:06 AM
Axle/Gears: 3.23:1
G*dd*mn all these home cooked solutions! A bolt would have been so much easier but noooo.
Old May 13, 2025 | 12:12 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Put it gear and put the park brake on?
W/an auto, stuff some rope down a plug hole.
Old May 13, 2025 | 12:35 PM
Axle/Gears: 3.23:1
Auto. Heads are off
Old May 13, 2025 | 12:51 PM
Engine: LT1, L400
Can ya....throw a "thing" in a cyl, bolt one head back on w/a couple two or three bolts around that cyl? Doesn't seem like a huge barrier.....
Old May 13, 2025 | 01:16 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Auto. Heads are off
Is the trans still attached? If so, put it in gear with the brake on. Or jam something in the flywheel.
Old May 13, 2025 | 02:16 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Helper with a screwdriver can hold the flywheel. Double nut it and the stud will come out unless the threads have been crossthreaded.
Old May 13, 2025 | 03:11 PM
Engine: LT1, L400
Auto. Heads are off
Old May 13, 2025 | 03:32 PM
Axle/Gears: 3.23:1
Win! Tried to fix the first 3-4 turns with a thread die and then tried a nut (the nut which originally held the balancer), and it stuck after a turn or two.....and when I backed it off the whole thing followed along. About time for some luck!
Old May 13, 2025 | 07:12 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Win! Tried to fix the first 3-4 threads and then tried a nut (the nut which originally held the balancer), and it stuck after a turn or two.....and when I backed it off the whole thing followed along. About time for some luck!
Side question, where are you buying your aeroflow parts from? I stopped ordering from them because it took so long to get here with their kangaroo delivery services.
Old May 13, 2025 | 11:53 PM
Axle/Gears: 3.23:1
Local parts shop here in Stockholm, Sweden
Old May 14, 2025 | 07:34 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Ah, I didn't even notice your location. Very cool.
Old May 14, 2025 | 08:47 AM
That "stud" is ... HEINOUS. I don't think I've ever seen a version of alternate-reality engineering quite like that before.
Old May 14, 2025 | 08:55 AM
Axle/Gears: 3.23:1
And I'm happy to replace it with something that wont make a good day turn to $hit (not that it did, at least not the whole day)
Old May 15, 2025 | 07:23 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
probably used to install the damper then just left on
Old May 15, 2025 | 08:06 AM
Axle/Gears: 3.23:1
Definitely a possibility
Old Jun 3, 2025 | 10:57 AM
Axle/Gears: 3.23:1
So today, after replacing small bits & pieces that broke while "fixing" everything, I started the engine with the new heads and the Summit 8800 cam. It fired right up. No leaky head studs - check. No leak from the new oil pressure sender - check. But, while adjusting the rockers (after the engine got up to 195 f) I noticed a puddle of engine oil at the front of the engine. It hasn't been leaking at all while doing all the work but when running and getting warm it started pouring. Looks like it came from behind the damper. Do I need to tear the waterpump, damper and timing cover down again to replace a new crank seal?!?? Or would it be a leak from the pan since I pryed back the timing cover lip over the old gasket? (it sat right, although no RTV on it). I understand you can't answer my question but since the amount was quite a lot (like two coffee cups over a 20 min period at idle rpm) the oil must have been slightly pressurized/forced in some way and maybe you could just give me a theoretical head start on what to look for?
Oh well, cheap gaskets to replace. I just really don't wanna fight with that gasket/lip seal again!
Old Jun 3, 2025 | 11:29 AM
Make sure there is a SHORT bolt with a drop of sealer on its threads, in the upper hole of the 2 down low on the front of the pass side of the block.
Old Jun 3, 2025 | 11:56 AM
Axle/Gears: 3.23:1
Will do! What happens behind it? Some oil passage?
Old Jun 3, 2025 | 12:53 PM
Yup... the fuel pump drive rod.
Old Jun 9, 2025 | 07:04 AM
Axle/Gears: 3.23:1
So, this weekend was extra exciting and fun! I saw no traces of oiI from the timing cover bolt, neither the damper. If oil were to leak from the crank/damper while the engine was idling the oil should have been flying all over the place. It had to be the pan gasket. This time I figured I had to let the pan a little bit loose to get the front timing cover to seal (to the pan).This is NOT coming apart again soon. NOT!! NOT until next weekend when I have to do it all over again.
When fighting with the pan I took away the oil cooler lines, which to me doesn't seem to cool that much, or? Should I put it back? Those lines are close to my header collector and I would prefer to just put the lines on the shelf for a rainy day.
So, questions:
* Oil "cooler" yes or no?
* I have a sleeve for the damper. Wouldn't hurt to use it, right? Just to kind of erase that possibility of leakage
Old Jun 9, 2025 | 11:19 AM
Engine: LT1, L400
So, questions:
The oil cooler lines should go to the radiator, the heat exchanger is in the side tank, I think. That or it's got water lines that go to the heat exchanger on the oil filter flange? Either way, there can be a lot of cooling (and/or heating in cold weather), especially if you're tracking the car or running it hard for extended periods. Do what GM did; use an oil cooler or run synthetic oil.
A speedy sleeve is a good repair for a grooved shaft (damper hub).
Old Jun 9, 2025 | 11:52 AM
The stock oil cooler in these cars does not circulate oil. It circulates coolant. The heat exchanger is between the oil filter and the block, not in the radiator. The lines carry coolant from the hot side of the system to the "cooler" on the block, and recirculate it back to the cool side, in parallel with the heater core. Since oil is usually at a temperature not too far different from the coolant hot side (usually 220°F or so) once it reaches equilibrium anyway, it doesn't really do awholehelluvalot most of the time.
Untold millions of vehicles have run small block Chevy V8s for 70 years now without an oil cooler, including the iconic muscle cars of the 60s & 70s, trucks, police cars, etc. Not sure why GM decided to put them on the TPI cars butt w/e... perhaps it had to do with getting the oil up to temp as quickly as possible for CAFE compliance at the time. Iunno, just a guess, nobody has ever told me. Given that the one used on the TPI cars is as much an oil WARMER as it is a COOLER, it hardly seems "necessary" or "critical", to the extent that it can't be done without.
I definitely agree w using synthetic oil (just yerbasic 10W-30, nothing fancy), and I'm perfectly OK w using a SpeediSleeve on the crank damper.
Old Jun 16, 2025 | 03:03 PM
Axle/Gears: 3.23:1
So, after a weekend, last weekend, under the car with my hair full of antifreeze, bruises, cuts and oil/dirt up to my shoulders the thing isn't leaking anymore and now hums along perfectly with its new 8800 cam. Will NEVER change cam with the engine still in the car again. Everything but the pan gasket was easy. That gasket drained my energy for many years to come
Darth 93
Sep 2, 2024 08:24 AM
6speedIROC
Aug 30, 2017 10:33 AM
justcallmeclassy
Aug 4, 2013 08:39 PM
Camarothatcould
May 29, 2007 03:28 PM
87Irocz
Apr 14, 2002 06:49 PM
