1986 TA oil pressure gauge jumping
Old Aug 4, 2025 | 07:18 PM
JGonzo20's Avatar
Hi, oil pressure gauge jumps to 60 holds for a second or two, then drops to 35. Engine is 305 carbed. Could it be sensor? Engine idles about 900. I’d so Is it above the oil filter or behind distributor? Thanks for help.
Old Aug 4, 2025 | 08:36 PM
Re: 1986 TA oil pressure gauge jumping
Sounds more like a bad connection where the wire plugs onto the sending unit.
There's no [mr_spock]sen-sore[/mr_spock] for that; only a gauge sending unit.
900 RPM is WWWWAAAAAAAAAYYYYYYYYYY high for idle. Sounds like, if you're quoting the number off of the wavy-pointer "sporty" trim package thingy in the dash, that THAT has gone bad, like everybody else's, in the way they ALWAYS go bad. Which is, they read WWWWAAAAAAAAAYYYYYYYYYY high.
89fast5oh
Sep 18, 2022 01:42 PM
shrewdpeach1609
Jul 23, 2016 06:01 PM
x91xCamarox
May 13, 2011 08:18 PM
geez28
Nov 23, 2003 03:25 PM
GCSIROC
Mar 18, 2002 02:06 AM
