Location of engine identification number (from above)
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
Hi all,
I just forgot the location of engine identification number that can be seen from above with the hood open.
My car is 1991 Camaro convertible with V8 5.0 TPI. There must be one that I can see from above easily.
Any information is welcome. Thanks.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Location of engine identification number (from above)
Front of passenger-side engine block deck. You may need to remove an accessory to see the stampings:
r.com/SGGRwWP.jpeg
I looked thoroughly at that area but couldn't find it, so probably I need to remove the AC compressor. I thought I could find it more easily before, but maybe that was my misunderstanding.
Car: 1989 RU7 1LE / 1997 RS
Engine: 305 TPI / 3800 Series III
Transmission: T5 / T5
Axle/Gears: 3.45 / 3.23
I was unable to see mine (stock TPI) due to wires and emissions in the way until I had to remove everything apart when replacing the fuel injectors.
Still have the original R7U block 😀
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Besides the suffix can use a mirror and get the block casting behind the drivers side head on the block. If original 305 it will have block number and 5.0 on the block.
Car: `86 SS / `87 SS
The deck will be bare on an original black-painted block. [ The orange above covers the location. ]
Thank you, guys.
I remember an inspector in the vehicle inspection in Japan found some number on the engine and told me it was the same as that on the inspection certificate and there was no problem, but I now wonder which number he was referring to. He couldn’t see any number on the engine without taking out any parts, could he?
camarosource
Sep 8, 2003 08:49 PM
