Can somebody identify the line?
Old Sep 26, 2025 | 06:48 PM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Transmission: 5 speed
I was cutting out floor on the passenger side and accidentally cut thru a metal line. No fluids leaked and car still started up. Does anybody know what this line is and maybe the best way to patch it?
Old Sep 26, 2025 | 09:21 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Can somebody identify the line?
that may be for the charcoal canister that would of been sitting in the passenger side battery tray
Old Sep 26, 2025 | 10:42 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
That does not look like a charcoal canister line. To me it looks more like a PS brake line. Brake lines are that small on the frame. Charcoal canister lines tend to be larger diameter.
Hope this helps,
Fred
Old Sep 26, 2025 | 11:50 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Is there a reason why you cannot make any effort to follow the tube to where it goes? Seems like there could be an answer waiting there for you.
Old Sep 27, 2025 | 10:41 AM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Brake lines go on the driver side and were recently replaced so they are new and shiny. This is passenger side and pretty rusty. Also, no fluid was leaking so definitely not a fuel or brake line. I don't have a lift and can barely squeeze under the car even if it is on the jack stands.
Old Sep 27, 2025 | 12:35 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Get bigger (propper) jack stands, you'll need 'em and should have 'em anyways. I agree with QwkTrip.
Old Sep 27, 2025 | 01:06 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Hardly anybody has a lift. We all use jack stands too.
If you don't have tall enough jack stands, then get yourself 4 jack stands that are tall enough.
I am 100% confident you will figure this out some day when you try.
Old Sep 27, 2025 | 01:43 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Where exactly is this line in reference to front and rear of the car?...
Old Sep 27, 2025 | 01:55 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Looks like that line runs up into the engine bay. No reason you can't follow it and learn the answer with a very small amount of effort. I'm certain it took more time to create your post about this than just follow the line. Your answer awaits.
Old Sep 27, 2025 | 02:45 PM
T.L.'s Avatar
'Looks like a brake line to me...
Old Sep 27, 2025 | 03:24 PM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
The line is on the passenger side sort of inside the transmission/driveshaft hump. The cut out on the photo is where a passenger would have his left foot.
Old Sep 27, 2025 | 06:13 PM
Engine: LT1, L400
^This.
But more so....
^THAT^
Old Sep 27, 2025 | 07:43 PM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
Its the line for the charcoal canister. It runs up the drivers side then crosses over to the passenger side just above the transmission bell housing. From there it runs along the passenger side frame rail to the charcoal canister.
Old Sep 27, 2025 | 08:10 PM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Thank you. Much appreciated. I guess I can patch it with just a rubber fuel line and couple of metal clamps.
Old Sep 27, 2025 | 08:49 PM
T.L.'s Avatar
I guess they changed a bunch of stuff over the years. The charcoal canister in my '83 is on the driver side...
Old Sep 28, 2025 | 11:59 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
You can. If you smog, the leak tester ( replaces the gas cap) may detect a leak. I used shrink tubing over a pinhole leak that failed, and it passed.
88BLKTransAmGTA
Jul 29, 2023 02:55 PM
akamoose
Mar 18, 2004 02:36 PM
