Wrong Tensioner ?
Old Nov 25, 2025 | 07:19 AM
Ndb270's Avatar
Wrong Tensioner ?
Rockauto calls for a dayco 89213 for 88-92 Camaro. My brackets are from a 3rd gen trans am. The guide whole on my brackets seems to be on the opposite side to match this tensioner. Am I missing something easy here ?
Drill another guide hole in opposite side for an easy fix?
Old Nov 25, 2025 | 10:56 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Wrong Tensioner ?
Looks like you have truck brackets. Camaro/firebird use the same brackets, truck and corvette are both different.
This is the style of belt tensioner the F-bodys came with.
Old Nov 25, 2025 | 02:07 PM
Ndb270's Avatar
Brackets are from a 3rd gen trans am not a truck
I should say I was "told" they were from an 88 trans am. Found this pic on forum. Super hard to tell if mine are different than what the f body brackets should be
Old Nov 25, 2025 | 03:25 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
truck
Old Nov 25, 2025 | 03:47 PM
Yup, you got fornicated
Old Nov 26, 2025 | 11:26 AM
Ndb270's Avatar
Well dang. Thanks for the help
Old Nov 26, 2025 | 11:49 AM
Ndb270's Avatar
Do these look correct ??
Old Nov 26, 2025 | 12:05 PM
TTOP350's Avatar
Yes, looks correct. Keep in mind, the waterpump, crank (ps?) pulleys have to match the brackets as well
Old Nov 26, 2025 | 04:04 PM
Ndb270's Avatar
The only thing I'm concerned about is getting the correct crank pulley. I have the correct wp and WP pulley, alternator and alternator pulley, power steering pump and pulley but the crank pulley I can't find good info on if it's 6 or 8 inches. The one I have is the 8 inch or 7 7/8" to be exact.
Old Nov 27, 2025 | 06:30 AM
I think the right one is about 6½" butt I could be wrong.
Sounds like it's time to hit the junkyard and just look at what's there. Probably a fool's errand to try to buy new; likely will cost outrageously, if it's even still available.
Old Nov 28, 2025 | 01:36 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
The crankshaft pulley on my 91 in 7 3/4".
go_topless
Feb 23, 2024 06:36 PM
BADMAN
Nov 30, 2019 08:33 PM
Camaro-3
Dec 28, 2018 02:18 PM
88IROCZILLA
Oct 17, 2018 10:32 AM
kins
24
May 27, 2007 02:47 PM
