Ported out 355 build
Old Mar 3, 2026 | 08:19 AM
Mrgeep's Avatar
What's up gents, Just looking for some opinions. Helping my son rebuild his 87 GTA. First time jumping into a 350 and fuel injection. Most of my experience has been in old international scouts. We had the block machined and ported out to a 355. Putting in forged flat top pistons. We.re going to pick up Aluminum heads and I'm not sure which Cam would be appropriate for our goals. We're looking to get this puppy to put out at least 400Hp but I've read that the TPI will hamper that dramatically. We like the TPI look and would like to keep it if we can. I've seen that they make replacement lower manifolds for the Tpi.
So my questions are, Is this achievable if we upgrade the Tpi base manifold
and What are your opinions on a cam for this application.
Old Mar 3, 2026 | 09:30 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Ported out 355 build
scout guy here as well
buy a rolled cehvy truck/tahoe/subrban and LS swap it.
the old SBC is nice, but a $500 Ls engine with a $250 cam will make 400 crank hp.
and get 22 MPGs and be lots more fun to drive then the old TPI engine.
-this is coming from someone who has done what youre goign to do, and whishes he never wasted the money...
Old Mar 3, 2026 | 12:54 PM
Mrgeep's Avatar
HaHa, Thanks for the heads up. I'll try to talk the little guy out of it but he really wants to keep the original engine.
My Scout below
Old Mar 3, 2026 | 05:06 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
A TPI 350 would be an excellent motor for this application, but it will never make 400hp.
Old Mar 3, 2026 | 05:50 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
HI Fun-factor...for the low(ish) mph.
B2k...you better not have LS swapped those IH's!!
Old Mar 3, 2026 | 07:08 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
3 of them are Ls swapped (1 stock 5.3, 1 LS3, 1 twin turbo 5.3) , 2 still have the 345s
Old Mar 3, 2026 | 08:48 PM
Engine: LT1, L400
BOOOOO!!
Hell YEAH!. There you go.
Went to a C&C last summer saw a patina'd IH Travelall there, nicely proportioned lift kit, not-too-big-wheels, w/properly sized tires to give it a great look....walk over to look at the 304 or 345 and....LSwhatever in there.
Waa....WAAAAAAA. (Debbie downer sound). Walked away.
Old Mar 3, 2026 | 10:13 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a 1966 1200a international pickup from our farm, I'm 2nd owner (still in the family).
trying to find a fuel tank and sending unit other than aftermarket sucks. Also need a water pump.
Or do i TPI swap it?
Old Mar 6, 2026 | 06:10 PM
Mrgeep's Avatar
So, even if I'm not going to be able to pull 400HP from this setup. Which Cam do you guys think will give me the most gains.
Old Mar 7, 2026 | 07:19 AM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
https://www.thirdgen.org/forums/tpi/...m_content=post
So I went through this. See recommendations. I ended up going with the Crower cam.
george88gta
Sep 10, 2024 04:28 PM
Jordan Ruddick
Dec 4, 2022 01:03 PM
MecGen
Aug 20, 2021 11:02 AM
Leviticus
Dec 5, 2019 02:57 PM
MasterEvilAce
Apr 14, 2004 02:09 PM
