Gounds on back of driver side head
Old Jan 25, 2002 | 11:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Hes my problem, after A dam near restoration of whe whole car I went to turn onthe ign to kick the fuel pump on to see if I had pressure. Well the pump didnt kick on, So i moved aroudnt he wires on the back of the head and made them tighter and now the pump kicks on. Are these grounds in conjuntion with the FP? Thanks
Old Jan 26, 2002 | 04:41 AM
Guest
Guest
Posts: n/a
The ground for the pump is actually at the tank, but the ECM and various other stuff (like probably the relay) ground on the engine at the back of the heads. That was probably it.
Old Jan 28, 2002 | 07:40 PM
poncho9789's Avatar
At least one of the grounds on the back of the heads are directly related in some way to the fuel relay I couldn't get the engine to start in my car for the same reason. I had missed 2 of the ground wires on the back of the head and the fuel relay wasn't kicking on.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Mutillator
Oct 1, 2015 06:05 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
