How much fuel pump?
Old Jan 26, 2002 | 05:16 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
How much fuel pump?
My inline fuel pump (EFI) finally went out. I am shopping for a new one. I have found ratings from 40gallons per hour to 100GPH. How much fuel pump is required for a 450HP engine?
I searched the archives and can't find a referance to a formula to determine GPH requirements.
Old Jan 26, 2002 | 06:43 PM
Engine: 4.0L
I found out, here's the formula:
www.lt1intake.com/engine_nitrous.htm
Turns out for a 450HP engine I need a 43GPH MINIMUM pump. That rules out the ones rated for 42GPH since that was their max flow. Damn the luck, I need the expensive one.
Old Jan 27, 2002 | 05:52 AM
jaymz's Avatar
have you seen this pump?
it may save you some money.
sohttp://www.autoperformanceengineering.com
Old Jan 27, 2002 | 06:27 AM
poncho9789's Avatar
Never mind I took another look at the formula and figured out my problem.
Old Jan 27, 2002 | 06:34 AM
poncho9789's Avatar
O crap I will need a 88gph pump with the nitrous!
Thanks for posting that link John
Old Jan 27, 2002 | 09:37 AM
Engine: 4.0L
Yes I checked it out. None of those external pumps are capable of more then 35GPH at 45psi.
Old Jan 27, 2002 | 07:55 PM
jaymz's Avatar
Sorry I missed the fact you were looking for a inline pump.
Old Jan 27, 2002 | 08:22 PM
Engine: 4.0L
I am going to settle on the mallory Series 110 model 5110FI pump.
It is capable of 110GPH at 50psi and is rebuildable even.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
