Steering gear box
Old Jan 26, 2002 | 11:32 PM
85roc's Avatar
Steering gear box
I have had the front end of my 85 iroc done and it still seems a little loose. Mechanic said it was steering gear box? and that it is worn and that is where the play is. Is there anyway to tighten it up without buying a new unit/ how bad would it need to be before you bought one
thanks, Tom
Old Jan 27, 2002 | 01:02 AM
Jza's Avatar
Jza
I would check the joints on the centerlink and tie-rod ends as well as the ragjoint before I assumed any slop was due to the steering box.
You *may* be able to get away with tightening the worm bearing preload on the steering box to get rid of slop, but beware: if you overdo it, you can and will destroy the gear. This is the little adjustment on top of the gearbox. You loosen the 5/8" jam nut, and use a 3/8" Allen wrench to adjust the preload.
Old Apr 6, 2003 | 03:13 PM
GilmourD's Avatar
How do you know how much to tighten? My slop is a few degrees in either direction. I just had an alignment done, and it's still not quite right, and I think that this is at fault because the steering wheel may look centered but really isn't.
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
