car trouble. Error 23
Car: 06 Toyota Tundra SR5
Error code 23 is the TPS, but I just replaced that as well as a new fuel pump, Ignition control module, O2 Sensor and a MAP. I wake up in the morning, to find my car is running fine, take it out and then the check engine light will come on, I push the gas and it seems to only push the car till a certain percentage of throttle is applied then it will stop pushing, even if i continue to add more throttle at the same time. I have no idea whats wrong, my TPS is brand new. And whats weird is, the light is still on, I take it back home, then a few days later I start it up the light may be on, Ill drive it maybe, and then the light will go off and it drives fine, but I notice that if I apply the brake and gas at the same time the light will come on, or if I WOT it from first and/or any gear I think, the light will come on, this is pissingmee off I need help.
I think Ill test the voltage today, what is the correct voltage? How would I test it at WOT? Usually I can WOT in park but I cant when Im driving. Also, how would I "adjust" the TPS?
Hope this helps, i think there may be a tech article on this here on the site if you need a better explanation of things.
Linson
Aug 21, 2015 02:12 PM
