Fouling my plugs?? won't idle..
Old Jan 27, 2002 | 06:10 PM
Alan84TA's Avatar
I'm still trying to get my rebuilt 305 (L69) running... My current problem is, it starts fine, but only runs for about 10 sec then dies... I can keep it running by pumping the gas and running it at higher RPM. I pulled a plug and it was dripping with gas.. however it will start right back up after it dies. What should I look at first? Carb was just rebuilt, new fuel pump, plugs, wires, cap and rotor...
Old Jan 27, 2002 | 06:54 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
sounds like the float is not correctly closing the needle and seat
to shutoff the gas flow..
very important to make sure the float is functioning correctly after carb rebuild.
Cornholio7979
Sep 20, 2018 02:31 AM
Derick15
Sep 17, 2016 05:28 PM
Bryan F
Aug 27, 2015 07:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
djmarch
Aug 19, 2015 12:07 PM
