winALDL
Old Jan 28, 2002 | 08:30 AM
Buck268's Avatar
winALDL
I have heard about it, but I dont really know what it is. Its a program that interfaces with my ECM, right? Well, how do I make/where would I find the plugs and wires needed to hook comp up to ECM. Also, any other info is great! Thanks!
Old Jan 28, 2002 | 12:05 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
I'll start you off:
the ALDL port that's near your knees under the dash, you just need to hook up a data and ground wire to it.. ground is A, and data E if i remember correctly. there's a simple schematic of the circuit you need to make floating around also. it only involves one transistor and 1 or 2 resistors. it plugs into the serial port of your laptop.
For more info hunt around the DIY Prom board. Even if you're not getting into prom burning there's enough info around there to get you started with the diagnostic aspects of the software.
Hope that helps. Anyone feel free to add or correct
--Jim--
Old Jan 28, 2002 | 03:48 PM
Buck268's Avatar
Thank you, I will check it out. I guess I have to get a serial plug then?
Old Jan 28, 2002 | 08:38 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Yeah, easy to pick up at radio shack, db9 female you'll need. its only like 5 bucks, little more if you buy a plastic casing for it
Old Jan 28, 2002 | 08:50 PM
Buck268's Avatar
Well, guess I will have to make a run up there soon. Cuz I'll need the resistors also...
92blue
Jul 18, 2002 09:52 AM
JoBy
Apr 27, 2002 07:55 PM
JoBy
Feb 9, 2002 06:08 PM
