Vents don't work...help!
Old Jan 28, 2002 | 08:21 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
Whenever I turn on my heat it come out of only one place, the defroster vents. When i put it on "vent" it comes out the defroster, when i put it on heat, it comes out the defroster. I dont kno what is wrong. I just replaced the vaccume tube from the vaccume canister because it was melted in two peices. It still doesnt work. What is wrong? Is the panel fried or are there loose wires or tubes. I dont even know how that system works. Anything would help me. Thanks.
Old Jan 28, 2002 | 08:46 PM
Chevy83Z28's Avatar
I think the selecter switch is electrical... check for fuses? If it's mechanical, maybe the linkage fell off. A fuse check might be a good start... sorry I'm not of much help.
Old Jan 28, 2002 | 08:59 PM
sleeper's Avatar
the controls in my 86 are vacuum actuated. If you were working on the car you may have disloged a tube. The main feed tube under the hood runs above the distributor and is clipped along the firewall... make sure it goes somewhere
chazman
Aug 28, 2018 03:25 PM
Redwhisper
Aug 26, 2015 05:02 PM
chazman
Aug 22, 2015 02:01 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
