Leaking drain plug ...
Old Jan 29, 2002 | 04:49 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
Any suggestions???
This is for my dad's 94 Chevy Suburban with 150,000 miles on it. A while back, he went to change the oil and realized the plug is stripped. He put I believe a one-over plug in and it worked until now when he tried to change his oil again. This time we tried a two-over plug, and a 3-over ... both leaked. Put a rubber stoppr plug in there worked for a day or so and leaked. Yesterday we got a 9/16 - 18 tap and re-did the whole. Bought a bolt and washer, it set up nicely and didnt leak. Today my father drove to work and came back to about a 1 foot diameter puddle of oil. He was only in work for 3 hrs. We backed out the bolt and tried a different washer ... still leaks.
ANY IDEAS .... WE ARE DESPERATE.
Old Jan 29, 2002 | 05:30 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
If it was my truck,i'd replace the oil pan like yesterday.You don't want to give it a chance to blow all your oil on the pavement and leave you stranded someplace.You might find one at a salvage yard cheaper than you think.My local yard has a whole bus full of the things.Make sure you get one for your one-piece rear main seal block though.If you want to get really butch,you could seal your drain plug with JB weld and get one of B&M's drain plugs designed for transmission oil pans.I installed one on my trans and it never leaked.Anybody got a better idea?
Old Apr 29, 2003 | 06:11 PM
KZad's Avatar
A little update -
We had a new oil pan put in the burban. Everything's fine.
However, now the plug on my 88 Formula's doin the same thing. I put a Single Over Piggy-Back in, and it leaks very little (drop an hour) but I still would like a new pan.
What are my options? I need one for my '88 L03, that would also swap over to my '86 350 block out of a Suburban. I plan on putting this motor in within the next year or so and would like to swap the pan over when doing so.
Is there such a pan that would fit both small blocks? Any comments welcome.
Thanks,
Kurt
Old Apr 29, 2003 | 07:54 PM
rockfourone's Avatar
well provided that it is ONLY leaking out of the plug, id just cover that baby in gasket sealant and that would be that!!!!
Infested
May 22, 2018 11:56 PM
LittleFranks
Sep 17, 2015 12:22 PM
Justin92GTA
Aug 27, 2015 11:16 PM
djmarch
Aug 9, 2015 05:27 PM
