AIR pump
Old Jan 30, 2002 | 06:31 PM
wickedRS's Avatar
AIR pump
Alright, I've removed my air pump, but now what. I've heard you can basically take all of the pipes off, but will this do anything really bad to my car. What will be the effects of not plugging the pipes, and how much can you actually take off. Thanks
Old Jan 30, 2002 | 08:43 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if you dont plug the pipes at the exaust manifold and at the cat youll have exaust leaks
Old Jan 31, 2002 | 05:27 AM
Keith Taylor's Avatar
I've taken everything off mine except the pipe that connects the left and right side exhaust purgers only because I cant get it out.
is it possible to remove this without pulling the engine?
Old Jan 31, 2002 | 06:05 PM
wickedRS's Avatar
Alright, I think I"m to the air diverter valve, and there are 2 electric connectors on it. Can I just disconnect those? Or am I pulling off the wrong component. My a/c and air components seem almost linked, and I don't want to accidently depressurize my a/c. Does anyone have a pic of their engine that has done all the work? Thanks
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
