What pistons with 58cc heads
Old Feb 1, 2002 | 10:38 PM
89blackbird's Avatar
I have read allot of stuff on the boards about 58cc heads and other posts about pistons. Bottom line what pistons should I use in my 5.7 standard bore and stroke with 58cc heads.I don't what a compression ratio higher than 10:1. If you have any part numbers lets here them.
Old Feb 2, 2002 | 01:18 AM
Hulk0202's Avatar
The only way to get anywhere near 10.0 would be to use dished pistons. That would probably bring it close. are these stock 305 heads. if so, its not worth the effort. they are very constrictive.
Old Feb 2, 2002 | 01:50 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
In a standard bore 350 block a flat top piston with a 1.54" compression height will have a 9.8:1 cr with 58cc heads
with a .039" felpro gasket. This piston will be .045" down in the bore on a stock block.
Try federal mogul # h-345p
Old Feb 2, 2002 | 06:11 AM
I will take a look at those pistons. The heads are 89 corvette heads not 305 heads. Thanks.
Old Feb 2, 2002 | 08:52 AM
GreenProStreet's Avatar
Dished, half moon type pistons actually make more power than flat top. More 'quench.' Kinda creates the Hemi effect. Also the turbulence and quench crated by these types of pistons will inhibit you from detonation, even if the car is tooned improperly.
Old Feb 2, 2002 | 09:34 AM
Hulk0202's Avatar
They will only help stop detenation if the pistons are a good smooth casting. The ridges can cause hot spots, which in turn will cause detenation.
Old Feb 2, 2002 | 09:59 AM
ede's Avatar
ede
i'd use a dished piston, break the sharp edges like was said above.
84z96L31vortec
Aug 20, 2017 12:16 AM
92projectcamaro
Jan 18, 2016 08:00 AM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
