Failed emissions - suggestions?
Old Feb 2, 2002 | 06:42 PM
Boham92RS's Avatar
I just failed emissions with my 92 CamaroRS - 305 TBI... here is the results:
HC limit - 1.20 gpm my result - 0.31 - PASS
CO limit - 20.00 gpm my result - 1.15 - PASS
NOx limit 3.00 gpm my result 4.57 - FAIL
Any suggestions to get the NOx down? I am swapping motors in March to a 350, but the inspection is expired now. Just want to get it to pass so I can drive it / keep it on the street
Thanks!
Old Feb 2, 2002 | 07:22 PM
Chronos_Titan's Avatar
When was the last time you maintenced the ignition system? Also does your air pump still work. The air pump should help lower your NOX emissions.
A high nox means that you are burning too hot. Bad carbon buildup in the combustion chamber can also cause this. If that is the case i would just write the EPA and tell them that you lost the engine and are putting in a new one in a couple months. I know you wont be able to drive the car but dealing with the carbon buildup is not worth it.
Old Feb 2, 2002 | 08:29 PM
Enkil's Avatar
Re: Failed emissions - suggestions?
Thanks!
Air pump doesn't do much for NOx, that's mostly for HC's. The EGR valve lowers NOx. Clean the passageways out, or buy a new one if that doesn't work.
Old Feb 3, 2002 | 03:16 PM
Boham92RS's Avatar
The igition system is fairly new.. MSD 6AL box, with msd cap / rotor, coil and superconductor wires. The EGR valve was replaced when I swapped manifolds, approx 6 months ago. Is there a quick fix I can try to get it to run a little cooler.. retard timing a little, etc?..
Old Feb 3, 2002 | 03:35 PM
Chevy83Z28's Avatar
Don't cats also reduce the NOx?
Old Feb 3, 2002 | 04:00 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
High NOx.......check the following:
-Engine overheating
-Lean air/fuel mixtures
-Vacuum leaks (can cause lean mixtures)
-Overadvanced timing
-Defective EGR
Old Feb 4, 2002 | 10:04 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i've seen stuff called all-u-need, pour it in the tank. they guarantee you pass emissions or double your cash back. costs ~$6.
Old Feb 4, 2002 | 11:33 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
What!? Where do you get it and does it work?
-Matt
Old Feb 4, 2002 | 11:50 AM
Car: '87 Camaro LT
Engine: 355 L98
i think it's made by bardahl, i got mine from Murray's Discount Auto. I've used it on two cars and both passed but they may have passed without it too so i dont know if it works.
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
